I just Recently put a new motor and started it drove it home. Woke up the next day to go somewhere go to start my car and nothing no power. I have a breathalyzer in my car due to dui, I can’t even get that to turn on the battery is fine new battery charged I tried jumping it nothing alternator is fine, but as I started to realize every time I hit the brakes and clutch to turn the car on I lose all power what is causing this?
    Welcome to Motor Vehicle Maintenance & Repair! It sounds like you have a very poor power connection. Check the main leads at both ends to make sure they are tight. Any higher amperage load can cause you to drop power in a situation like this. – Pᴀᴜʟsᴛᴇʀ2 Apr 20 '20 at 0:22
    Did all the ground cables get reinstalled and tightened on the engine? Did the starter battery cable get tightened, double check the work. – Moab Apr 20 '20 at 2:44
  • I did actually just the ground an tighten them up I got it started now I thing the tps is acting up – Heaven Stout Apr 21 '20 at 13:06
