I have a Citroen DS3 that was running fine until yesterday.
I had an engine warning light come on, the car was still driving fine, then my car wouldn't restart. Before it cut out there was a strange whirring noise after I took the key out.
I managed to start it again with a jump, but did the exact same thing happened when I tried restarting it a few times, but now the engine warning light has gone.
Any ideas?
  • First charge the battery properly then retest and check for any codes.
    Apr 16 '20 at 6:03
  • The warning light is important here. You'll need a scanner tool to read out the service code which will likely help you determine the issue. It sure sounds like an electrical problem. Perhaps a bad battery, alternator, alternator drive belt or a combination of these.
    – jwh20
    Apr 17 '20 at 13:20
