A number of faults can trip the check engine dashboard indicator and must be checked with an ODB meter to decisively identify the fault.
I was just informed that "the car's nighttime rear lights don't work." Does this failure mode trip the check engine dashboard indicator?
    Not sure on your camry, but some cars will notify you via a diagnostics screen on the dash you have a burnt out bulb or such. Your car being a 98 I would be hard pressed to think it would have this feature. I don't believe it would show up as a CEL or viewable through OBDII connection. Apr 8 '20 at 15:13
Not the check engine light but on newer cars it may set a code in the Body Control Module, which has to be read with a good quality obd scanner, but there is no light for that since it is non critical and not part of the OBD standard yet.
  • How does one know if one has a good quality OBD scanner? Is there a particular feature or make / model?
    – gatorback
    Apr 8 '20 at 17:39
  • That's a mixed bag on the ones in sold parts stores if they can pull BCM codes, ones used by repair shops can for sure.
    – Moab
    Apr 8 '20 at 23:25
