Based on OBD II Standard PIDs
PID(hex) 11 Throttle Position value from 0~100%
How could we use this data to predict if there is going to be a problem?
https://en.wikipedia.org/wiki/OBD-II_PIDs
  • What data do you have? What symptoms do you have? What car do you have? vtc as this is just a link...
    Mar 17, 2020 at 7:11
  • I just wanna to create a general method to detect the relevant problems
    – Sean
    Mar 17, 2020 at 10:06
  • Welcome to Motor Vehicle Maintenance & Repair! Please take a moment to take The Tour as well as read through the Help Pages. Mar 17, 2020 at 11:52
By using OBD to get some key data, I developed a method to detect "throttle" related emission problems.
=== Background ===
The engine of the vehicle goes into the idle state (engine speed > 0, vehicle speed = 0) when waiting for the traffic lights. If the engine does not obtain enough air because of a throttle related problem (but not worse enough to flameout), then ECU will control to inject less fuel to maintain an Air/Fuel rate. The engine speed will drop (a small or big variation).
=== Method ===
  1. monitoring the "engine speed" —— to detect the abnormal variation
  2. check the changing rate of the "throttle position" —— to check if the throttle is getting stuck somehow
=== About the Maths ===
S - engine speed
T - target idle RPM
e - variation tolerance of engine speed during the idle state
if | S - T | > e, then the idling engine speed is not stable
p - throttle position
t - time
R - the changing rate of the "throttle position"
R = ΔP/Δt
if | R_max - R_median | > e during a period of time,
then we could say that R is not stable, which means, he throttle is getting stuck somehow
=== Data collected from OBD ===
  1. engine speed
  2. vehicle speed
  3. throttle position
=== welcome to post your thinking ===
