If a car starts, I assume it means there is enough cold cranking amps to start the car. Therefore if it cuts out after a few, 10, or even 30 seconds, it means the cut out problem is definitely not related to your battery's CCA. I just want to check that my assumption is correct.
  • You've received a comprehensive answer from Fred_dot_u to the question you asked. Asking a new question regarding which other systems to suspect would be a proper next step.
    – psaxton
    Mar 15, 2020 at 21:11
  • @psaxton he seems to be implying less then 10 seconds maybe a problem and I did mention a 'few seconds' in my question too. Unless I am interpreting his answer incorrectly and he is saying an immediate cut out after a start means no cca or starter problems. Mar 15, 2020 at 21:16
  • @JamesWilson if the starter is able to turn the motor the battery is fine. Also CCA is about performance in extreme temperature conditions, it is mid March so unless you are in a polar region you probably are not operating in extreme cold.
    – Ukko
    Mar 16, 2020 at 14:05
  • A separate question helps future internet people to find and resolve their problems as well.
    – psaxton
    Mar 16, 2020 at 22:04
8
If your engine turns over fast enough with the systems operational in a manner sufficient to start the engine, even if the engine is running only 10-30 seconds, and you've released the key from the start position, the battery/starter circuit is out of the picture.
Your assumption is correct.
  • what about less then 10 seconds, and if its a problem why? Mar 15, 2020 at 17:06
    @JamesWilson: It takes a few cycles for some alternators to start working. I've actually had my truck stall because I let go of the starter too fast.
    – Joshua
    Mar 15, 2020 at 22:13
    When the engine dies immediately after releasing the starter the first suspect is the ignition resistor.
    – Hot Licks
    Mar 16, 2020 at 2:13
  • I have gone on to find that while a starting car should mean the cca is ok, cutting out doesn’t mean the battery and starter circuit is ok. In this case, the cut out was caused by corroded battery terminals. Oct 31, 2020 at 20:40
