I have a Mitsubishi Lancer 2003 automatic transmission car. When it is in drive mode and stationary (brakes pressed) the engine starts to vibrate.
Could anyone be able to let me know the how to fix this issue.
Thanks & Best Regards
Michael
Sign up to join this communityThis sounds like one of 2 things to me:
First, I would get under the hood and look at the ignition system. Look for loose, damaged or oily spark plug cables, pull the spark plugs and check them. Also get a flashlight and check the motor mounts you can see (if you can see them, I have no idea with a Lancer), you may be able to tell if they are shot with a visual inspection.
Next I would read the car's OBD codes, most auto stores will do this for you for free, you can also get inexpensive USB or bluetooth readers and do it yourself. I personally use a bluetooth reader paired with an android tablet and the Torque app. If there is a cylinder misfiring the engine computer will probably throw a code telling your which one.
