My car Opel Corsa 1.4 2009 is been driven just 36k km. A strange problem started a few days back. When I drive more than 10 km in city and restart the car with a small wait(<5 mins) the car hesitates in a few km and eventually doesn’t move at all. If I wait for like 20 mins and start again the car goes on normally unless the stop/start happens after next >10 km. I thought it was the fuel pump/filter/O2 sensor but all looks good. After having the issue repeatedly, I understood its the brakes that engages on its own and I’m just pushing the gas with brakes on, making the car vibrate with a strange smell.
On opening the brakes I see the front brake pads and disc are quite damaged, no wonder I had put a lot of strain to move the car to understand the problem. Certainly the brakes needs to be changed but I still don’t understand whats causing the brakes to engage. Even if I change the brake it might get damaged again.
Can some electrical or hydraulic be the reason? Since my car has ABS, can the ABS trigger suddenly?
The car needs to be driven for a while before the problem occurs so I guess something is happening because of the heat. Can anything in the braking system expand due to heat and get engaged if not electric?
Note: No codes from ODB2 reader.
