Provided that the oil filter of an engine would be swapped every x time intervals as needed to be kept clean, I was wondering if, instead of removing all engine oil and replacing it with new (clean and uncontaminated), there would be any advantages in adding clean oil in shorter intervals and bleeding the same amount of the dirtier oil (probably left in the bottom most of the oil pan). This suggests that no oil leaks and oil consumption takes place. Would such a method provide better cleaning/flushing of the engine parts? The idea here is that replenishment will keep oil in an overall good/clean condition. If this method keeps the oil at an overall "cleaner" state would it help to prolong the filter longevity as well???
Its not just contaminants, oil does wear out and needs to be replaced>>>>>amsoil.com/newsstand/motor-oil/articles/…– MoabFeb 25, 2020 at 14:42
The short answer is convenience. It's just too much to ask of the average consumer to perform a drain-and-top-up procedure at regular intervals.
It's also messy. Anyone who's topped up oil without a funnel can attest to that. And once the drain plug is undone, you can't turn off gravity at will to prevent spills.
Not sure about this. I tend to believe that modern mechanics are able to produce easy operated oil inlets/drains. Also i didn't actually mention that the end user should preform this task so there might be actually a "market" advantage.– kokobillFeb 26, 2020 at 14:31
Some manufacturers do this - at least on larger equipment.
The oil is rated for 100,000 miles and the filters changed every 10,000 or 20,000. The oil is topped up as necessary. And, in some locations they are very quick to sort leaks so they don't contaminate the terrain...
I did this on a car kept the fully synthetic in for twice the recommended interval but changed the filter as per spec. Engine was fine, but I was using Mobil 1 5W-50 and it was really expensive then.
1That doesn't seem to be exactly what the question is asking (only partially changing oil often, vs. complete changes per spec)– toweFeb 25, 2020 at 9:54
1@towe then do an answer based on your experience - that should help. Feb 25, 2020 at 9:59
Railroad locomotive diesels rarely have oil changes ; 100,000 +. They are topped off and lab tests determine if any additives need replacement. Feb 25, 2020 at 15:39
