My daughters 2012 VW Jetta stalls intermittently while driving. We've had it towed several times, and by the time it reaches the house it starts up again with no problem. Other times when it hasn't been towed, it started back up with in a few minutes to an hour, and acts like nothings wrong. It is also leaving no code.
After it stalls, during the time it won't start, the starter seems to be turning over fine. The battery is recently replaced, and it's been checked even while stalled. We've also tried jumping it while its in the stalled state but that doesn't seem to help.
The VW mechanic has had it a few times, and changed the crankshaft speed sensor/position sensor based on the symptoms. But they haven't been able to replicate the problem.
I'm still paying on it, so would like to get it fixed.
Is there something else I should try; fuel pump, fuel pump relay, ignition switch?
Has anyone else dealt with a similar issue?
