New to forums so please be gentle 😁
I am having intermittent issues with our 2007 Citroen C4 Grand Piccasso and am hoping to narrow it down slightly as I understand this could be any number of issues or potentially several seperate issues...
Symptoms are as follows:
Has cut out several times now whilst driving, doesn’t appear to be fuel related as it doesn’t sputter etc, just engine off, once I didn’t even notice it had stalled for a few seconds. After cutout sometimes it restarts immediately, other times the is one click noise on turning ingnition then nothing, and other times (like today) the starter cranks continually but will not start.
I have noticed that on all occasions that this has happened the car has started successfully after a period of time (cooled down?) and driving is fine until the next time...
I have been told it could be Coil, ignition switch, faulty alternator, battery (I have put a new battery in now with no change) fuel pump, ECU computer, wiring harness. I am hoping to narrow down a bit or at least get the most likely one from the symptoms as I can’t do any of work myself and can’t afford to take to the dealer
Thanks in advance
