I have a spare wheel that I need to take out of the trunk of my Nissan Pulsar, but the middle bit always slips when I try turning it.
I think it's fixed too tightly. How do I remove this thing?
Sign up to join this communityI have a spare wheel that I need to take out of the trunk of my Nissan Pulsar, but the middle bit always slips when I try turning it.
The blue plastic spacer (that keeps the wheel central) has split so it slips around the bolt head.
Prise the plastic part out (you'll have to break it) so that you can undo the bolt directly. Then replace the plastic surround.
Alternatively, you could try gripping the bolt head and its plastic surround with a mole wrench and undoing it that way, but it still needs a new plastic part.
Don't tighten it hard, only by hand (it's a handle), just enough to hold the wheel in place. First, apply a very small smear of grease to the threads at the tip of the bolt to make it easier to undo next time.
