2012 nissan murano interior light doesn't go off after door is closed. It does go off after 15 min. as it says in the manual.
Which light ? The front dome light switches on by pushing it, it will click. If the door is open , the light is on so if it is pushed at that time nothing happens ( it is already on) . But when you close the door it stays on until the timer turns it off . I have inadvertently done that and wondered why the light does not go off when the door is closed.
| improve this answer | |
  • Thanks' it is the dome light and I have tried all 3 positions. It does turn off in the off position and it stays on in the far right position but when youclose the door in the middle position it won't go until it times out in 15 minutes. – fred matteson Jan 31 at 20:45
  • Mine is a 2011, in the middle position the light goes off in 10 seconds. But if you push the light lens , there is another switch that turns on the light. – blacksmith37 Jan 31 at 21:38
