2013 Hyundai Accent 255K miles. Runs great, still gets around 35 MPG. 40K miles ago I was having trouble with 420 code. Did usual tune up stuff and both O2 sensors. Ended up replacing the Cat with an aftermarket from Eastern Catalytic. I noted that the old one had no carbon or scale, I've seen very nasty Cats before.
When I changed the plugs about 15K ago they were normal, no heavy fouling. Now I'm getting the code again after only 40K miles. I think it's a false code caused by something else. What's odd is if I clear the code with a scan tool, turn off the key, turn it back on, and check the scan tool, it still has 2 420 codes, 420 generic pending. I think this is weird since I haven't run the car after clearing it. I did some work recently and had the battery disconnected for 4 hours and the code remained.
Any thoughts?
  • When was the last time the post cat lambda oxygen sensor was replaced?
    – GdD
    Jan 27, 2020 at 13:19
  • The post Cat O2 sensor was replaced about 50K ago trying to stop the original 420 code. It's on my to-do list to replace to see if it helps but I have my doubts. It didn't help last time. Wondering why the "pending" code won't clear from the computer though.
    – soulTower
    Jan 27, 2020 at 18:07
