Car: 2001 VW Golf
It was late at night, I was in a hurry and like an idiot I forced the hatchback closed. I tore out the nut insert (don't know what else to call it) that one end of the hydraulic lift strut anchors to.
Is there a way to replace the nut insert myself or is there some way I can hack the hole so that I can screw the bolt in? The strut bears a fair amount of weight so it would need to be a sturdy hack
The gaping hole where the "nut insert" used to be.
This is the other "good" end showing what the nut insert looks like:
I see the following possibilities:
  1. Insert a rivet nut. That is a simple fix but there is a slight possibility that it won't hold.
  2. Ask a bodyshop to weld the ball joint, ideally with an small reinforcement plate, to the car body. The definite solution, albeit expensive.
You could use a small triangular file to shape the existing hole into a female hex and use a hex rivnut.
Flat Head HEXNUT Body is provided in both a standard and heavy hex design. The heavy hex design features a larger body diameter that results in increased thread strength and torque capability. The hex body design provides the ultimate in spin-out resistance when used in a hex hole. The RIVNUT® is designed for use with Property class 5 mating hardware. A grip ID mark is included on the head of the fastener for grip range identification.
 source: RIVNUT® Flat Head Hex Body
Rivet Nuts (aka RivNuts) are also available with a spline that holds the RivNut instead of a hex. If you go this route, you might have to drill the hole to the correct size.
Some RivNuts need an installation tool. Essentially, you tighten in a bolt that expands the bottom of the RivNut so it cannot escape the sheet metal hole. See the difference between the second and fourth image above.
I got familiar with this fastener when I installed some auxiliary bash/skid plates under a Ram 1500 4×4 so as a fastener they can take a fair amount of stress.
  • That looks perfect. Can I buy just one? :-) – No Grabbing Jan 25 at 0:49
  • You might find them in the bulk bins at Home Depot's Fastener aisle but they are a specialty fastener so I'd call around first. Remember, it the regular RivNut for your bolt is already loose in the existing hole, they also come in a heavy duty version that would be larger across the hex. – Jeeped Jan 25 at 1:01
