Opel astr g z18xe 2001.i have just changed my clutch plate only not the pressure and flywheel plate. Gear box vibrates when it is on 1st gear even on reverse. Why?
  • A mounting left loose or you got grease or oil on the centre plate
    Commented Jan 21, 2020 at 20:04
  • Welcome to Motor Vehicle Maintenance & Repair! It sounds like you should have replaced the pressure plate and flywheel when you had the work done. If the friction disk is toast, more than likely the PP/FW also need to be renewed. Commented Jan 21, 2020 at 22:06
