Is there a way to make both the high beam and low beam lights on when turning on high beams? My car has two separate bulbs that switch back and forth. I would really like the extra coverage.
  • Drive the low beam relay from the high beam relay using a diode. – Solar Mike Jan 21 at 5:21
  • @SolarMike - That's a good answer. You'd need a heavy duty one to put up with the current flow, but it would. You should make an answer out of that. – Pᴀᴜʟsᴛᴇʀ2 Jan 21 at 13:55
You can drive the low beam relay from the high beam relay using a diode.
I would use a small diode to go from the coil supply on the high beam relay to the coil supply on the low beam - this only requires that the current increases by the amount to energize the coil - combined that will be less than 1A.
If you do this on the output side of the relay then you will have the low beam relay supplying all 4 bulbs ie about 20A instead of 10A...
Do make sure that the relays are supplied separately, otherwise you have the same current problem on the supply side. If that is the case then I would run new fused supplies to the relays.
  • Note: the bulbs are NOT designed to work that way. Expect them to burnout very quickly from the excessive heat. This is not clever. Cheaper, easier to purchase better bulbs then have the headlights carefully aimed, so the cutoff is just below horizontal. – zipzit Jan 21 at 16:00
    @zipzit is that because you have dual filament bulbs? I have 4 headlights - two each side, each one has its own bulb so 4 separate bulbs... And they most definitely are designed to work that way. – Solar Mike Jan 21 at 16:11
