I searched the web and I searched this Stack exchange and I've only found answers that seem to apply at all times (static electricity is always possible, and the engine doesn't cool THAT much in the 30 seconds it takes me to pay and put the nozzle in the tank).
What is the danger? What mechanism would lead to this issue?
    Go back to when, or before, that law / rule was invented and tesearch.
    Jan 18, 2020 at 20:39
    May depend on the vehicle : I was refueling a running motor bike once and stepped back just in time to save my eyebrows and likely other stuff. The gas tank was directly above the hot engine. A little paint and new rubber hoses and everything was good. Jan 18, 2020 at 21:02
  • @SolarMike it exists in jurisdictions all over the world, and I've not been able to find anything about where or when this began. Do you know or have a suggestion for web search terms? I'm new to learning about cars. Jan 19, 2020 at 1:52
I don't think it has anything to do with static electricity (which can happen anytime, always touch your car before the pump handle!) or your engine being hot. More likely its to cut down on as many extra factors as possible that could ignite the vapors. How ever unlikely it is to happen consider this, with the engine on(or even just key switch on) there are many moving parts that could cause some type of spark. There are also many more live electronics in the car that could fail spectacularly at anytime. With the engine/switch off these items are dormant so it greatly reduces the chance they could ignite any fuel vapors.
Side note, I was at the pump across a guy once who was fueling his scooter. He either had it running or he went to start it while fueling. It caught a small fire directly above the tank. He tried to extinguish it with the bottle of water he was drinking which made it worse, then he tried his shirt which also caught fire. There was no explosion but it grew steadily til it consumed his scooter and then the entire pump. I had my 3yo son at the time in the back seat so I stopped pumping and got out of there at this point.
The wawa station at the time had the fire extinguishers hidden behind trash cans on the ground. They have since moved them up higher where they are more visible.
