Why doesn't polarity matter for fuel injectors? If they are essentially a solenoid, then it seems it would matter; swapping polarity would change the direction the electromagnet pulls or pushes.
1 Answer
Like normal magnets, electro magnets can only attract (pull) metallic objects, so the injector coil could not repel the solenoid valve.
