2012 Mini Cooper w/ 72,000km on it (about 40k miles). Just had mechanic put on new pads and rotors on all 4 corners. Old brakes were constantly rubbing and making noise. A different mechanic said my front pads were wearing out and needed service on caliper slide pins. They also said my rears were wearing very heavily on the inside pad, but not the outside.
Took the car to a different mechanic to do the work. He said the rear calipers were extremely hard to compress+spin inwards (he deals with a lot of bmw/mini so I'm sure he was using the right technique with the rotation).
After he took the car for a drive after the install, he put it back on the lift and was looking at the rear brakes. He came back to me and said he hears knocking and it is likely due to rear caliper piston seizing issue. While I buy that he says my rear calipers need replacement, I don't completely buy that a cyclical knocking sound can be caused by a seized caliper.
Can someone explain this?
  • Welcome to Motor Vehicle Maintenance & Repair! Dec 27, 2019 at 20:43
    I tend to agree that seizing doesnt seem to be the cause for knocking, but I'm definitely not a pro (or indeed at all experienced) with Mini's. Generally cyclic noises point to either warped rotors or damaged bearings from my experience. But, not being certain, I hesitate to put this as an answer. Dec 28, 2019 at 0:26
  • Just to confirm, the rotors have been replaced recently, or are they due to be replaced by this mechanic?
    – GdD
    Dec 28, 2019 at 13:26
  • That's a valid answer in my book @kyle_engineer.
    – GdD
    Dec 28, 2019 at 13:29
  • After bringing it back to the mechanic, here's what was concluded: 1) Old rotors didn't cause knocking. 2) New rotors caused knocking. We suspect a defect in one of the rear rotors (Raybestos Coated) 3) Mechanic installed their own rotors, which solved the problem. We also found that there was more knocking from the front rotor, which we thought was another bad rotor. Turns out it was a front wheel that was left loose (lug nuts were on, but not torqued to spec).
    – Mark S
    Jan 11, 2020 at 1:56
It looks like the I actually had a defective rotor causing this issue. But don't forget to check your lug nuts over as well!
