I have gotten a car battery charger as a present which is rated at 6A max and is also labeled up to 65Ah max.
I'm not understanding why there is a battery capacity indicated on the charger when the battery will keep getting charged for as long as the charging voltage is greater than the battery's voltage.
Say I have a 100Ah battery which requires around 10A to get charged, with this charger it should take roughly twice as much time, but the charger should still be able to charge the battery.
Why is there a capacity label on the charger?
