I have a problem with my ibiza 1.6 mpi engine 110 hp. I can't exceed 150 km/h but in inclined roads i hardly reach it 170 km/h with a cut in engine what do think the problem is due to although the computer shows everything is ok.
Serviced it lately? oil, filters? checked the brakes?– Solar MikeDec 22, 2019 at 21:30
Everything is alright oil filter air filter I have also changed spark plugs.– Boucenna salaheddineDec 22, 2019 at 21:48
Notice that the cars behaviour under 150km/hspeed is very normal– Boucenna salaheddineDec 22, 2019 at 21:49
1 Answer
The technical specs for your vehicle are listed here:
They list a MAXIMUM speed of 187 km/hr. So your 170 km/hr is close enough to that figure that I suspect there is nothing wrong. The 187 figure was likely obtained under controlled conditions at a track where you are running on a public road with varying conditions.
This is not exactly a "performance" vehicle as the 105 HP listed is quite low for a vehicle that weighs more than 1000 kg.
I have I reached 150 km/h but 170 I couldn't reach it in flat road but in descending one with cuts in the ignition I think Dec 23, 2019 at 11:41
