on my 2003 Nissan Murano, a wire short occurred and melted many wires, I separated them and replaced the damaged wires. Now I have a code U1001, U1000, P1212 and so on, my car will start and only idle, no acceleration, indicates battery signal even when alternator is working. I have removed my entire dashboard and diagnosed many components, cant find the issue. What can i do
    Welcome to Motor Vehicle Maintenance & Repair! Seems like your CANBus isn't communicating correctly (U1000 & U1001). You still have an open circuit somewhere you haven't accounted for. Dec 21, 2019 at 14:42
  • I suppose, Is it possible that it could be due to weak battery?
    – Shoogarh
    Dec 21, 2019 at 14:45
  • I'm doubting it, however, if you think it might be, charge it. If it's a bad battery, replace it. Dec 21, 2019 at 14:53
  • Your battery has to be good and fully charged before any of these things can be properly diagnosed. But as mentioned above, I think there's more to it than just a weak battery.
    – Jupiter
    Dec 21, 2019 at 21:02
  • I bought a new battery, checked and tightened all the ground terminals, grounded the ECU as it was not grounded while i was running the test. started it and its still the same thing.
    – Shoogarh
    Dec 21, 2019 at 22:16
