can any clutch be used with the DMF or or you required to use a "dual mass clutch" as advertised by retailers>
  • Welcome to Motor Vehicle Maintenance & Repair! Dec 15, 2019 at 13:18
Use the proper parts otherwise you get to take it apart again.
Some have changed to a solid flywheel and clutch which worked for some but not all, they got to replace with dmf after...
