Why one output terminal of my car ignition coil gives less sparks than the other terminal. In fact, the 2 terminals are control by a single primary circuit of the same ignition coil!!! The other ignition coil has the same issue.
I have checked for all resistance readings of the PRIMARY AND SECONDARY CIRCUITS of each IGNITION COILS which shows normal values. No cracks, etc etc at all.
Please kindly help.
Thanks.
