I was at a traffic signal with my car on nuetral. When the lights turned green, I accelerated without realising the car was still on nuetral. I then immediately shifted into drive while the engine was revving. My car jerked initially but then drove normally. I didn't realise any abnormalities after that while driving.
I'm worried I may have damaged my transmission. Will shifting into drive while accelerating usually damage transmission or is it something I dont have to worry about.
My car is a 2016 Honda Accord coupe (Automatic transmission)
Yes, if done excessively, it is possible to damage your car doing this, you could -
  • break a CV joint
  • break a universal joint
  • strip a driveshaft spline
  • damage the gearbox
  • tear a rubber coupling
  • damage an engine mount
and probably damage a number of other things.
If the car is driving as normal, then I wouldn't worry about it. If you start hearing knocking noises after doing this, then you need to get the car checked.
    No clue who downvoted, but gave my uptick for a good answer to counteract. Nov 22, 2019 at 22:06
Once probably won't damage it unless you are unlucky.
Doing this repeatedly will eventually cause damage sooner or later and that is usually a transmission out and overhaul / replacement - which is not cheap...
  • Probably "sooner". Nov 22, 2019 at 22:07
  • I did twist off the transmission tailshaft on a hydromatic doing that; However i was very young an foolish at the time. and did not repeat. Nov 22, 2019 at 22:10
