So I have recently changed the Idle Air Controller, Coolant Temperature Sensor, Spark Plugs, Rotor and cap. The CTS was in regard to this latest problem which did not help.
Symptoms: When starting cold the Engine runs very rough at idle sputtering and will die if I don't give it gas. When I rev it the miss goes away until it is warmed to ~120F indicated on my dash then it runs OK.
PS: Checked the fuse to the cold start injector and it was good. Fuel pressure ~43 psi.
Does anyone have any ideas what could be wrong?
