The last couple days my CR-V seems to die after I’ve driven some distance... the first time it happened I turned the car off, opened the door and tried to use the button on the driver side door to lock all the doors and nothing happened. Then tried to lock the doors from the outside manually using the key (the fob battery is currently dead) by turning it twice to lock all of the doors - nothing. Then got back into the car, no lights came on. Tried to start it and nothing, not even a click. A couple minutes later it started up just fine. Locks worked, lights came on... no problems... just happened for the second time this morning. Gave it a couple minutes and it started up just fine. Any thoughts/ideas??
  • Welcome to Motor Vehicle Maintenance & Repair! It sounds like the battery is dying. Take it to a shop and have it load tested. – Pᴀᴜʟsᴛᴇʀ2 Nov 7 '19 at 17:24
