-1
As winter comes the temperature will get colder and colder. Will this affect my car? I want to be prepared for any problems that will cause any start up problems or driving problems.
Thank you.
    Yes. Tires will get stiff, will take longer to get heat from the radiator to warm the interior, steering wheel and seats will be colder. Fuel/air mixture will be adjusted to counteract the thicker/denser air. I believe fuel blend itself is also changed for winter by the distributor. I notice in my turbo-diesel that my fuel economy (mpg) drops until the engine warms up.
    – CrossRoads
    Oct 31, 2019 at 15:50
Maybe most importantly the battery performance degrades as its temperature drops.
So, lower battery output combined with a cold engine, thicker oil etc and the starting task is much harder...
