Let's say there is a problem with the AWD and it's too costly to fix it. Is it possible to leave it unfixed and use the car as if it was a FWD?
If yes, would leaving it unfixed have any adverse effects on other parts of the car, or to the AWD system?
A particular example would be 2010 Toyota Matrix.
Possibly. It depends on what is wrong with it and how the AWD is setup in the vehicle. About the only way this could work is if a rear drive line had gone out (like u-joints) and it was removed. The rear differential would free spin and the front wheels would provide the drive power. Overall, as compared to the rest of the system, the driveline is a relatively cheap fix, so I doubt this is what you're talking about.
That said, if almost any other part of the AWD system which transmits power to the wheels goes out, you're going to be out of luck. Take for instance the differential. If the rear diff goes out, you aren't going anywhere. If the transfer case goes out, there's no transmitting any power anywhere. If the system is engineered to provide power to the rear first, with the front used as backup traction, that's not going to work, either.
Really, if the AWD system is broke in an "expensive way", you are pretty much either going to have to get it fixed or let the vehicle sit.
  • I see. In that case AWDs don't power the front wheels first and then transmit that power to the rear wheels. They power the transfer case, which then powers both the front and the rear wheels I guess.
    – Utku
    Oct 25, 2019 at 21:10
  • @Utku - It depends on the system, but it can be done that way, yes. Oct 25, 2019 at 21:53
This depends on the system.
One with a centre differential can drive the front, or rear, only but must have the centre differential locked otherwise it will just spin...
Vehicles that did not have a centre dif only need to be locked into 4wd and driven.
Done both of the above as have broken rear halfshafts and got home doing exactly as described.
