I bought a used mini excavator (Terex HR1.6).
I followed the overflow hose from the radiator. It ends in free air – i.e. no overflow tank or valve or anything.
I have the machine's manual, and I can't find any mention of an overflow tank.
Was the machine likely built without an overflow tank?
    Nothing had radiator overflow tanks until after about 1970 as I remember. I rigged a few before they were standard and got some unusual looks. Just stick the end of the overflow hose into a container. Oct 19 '19 at 21:42
  • Not True.....Ford had them in the 60's on their FE engines, they were made of brass.....dearbornclassics.com/…
    – Moab
    Oct 24 '19 at 15:46
What @blacksmith37 says is true, kinda. You could stick the hose into a catch bottle, and that would tell you that coolant is coming out during high load, high temp conditions. That's it. The coolant in that bottle WILL not go back into the radiator during cool down, like in a more modern cooling system. What makes that work in a modern flow back overflow system is a dual seal radiator cap.
Dual Seal Flow back radiator cap
You could possible find parts to make that work, but in the meantime, just check the coolant level often by removing the cap in looking in the tank. Note: Get in the habit of doing this when the engine is cold. Never open a cap on a hot engine. Safety first. There are some conditions where opening the cap on a hot engine results in a dramatic coolant / steam eruption. (Normal coolant systems are pressurized between 13psi and 19psi, where water boils at up near 250 def F. If your vehicle is at 240 def F and you open the cap to atmospheric pressure, that coolant in your system will want to convert violently from liquid to steam vapor with dangerous results.)
