Here is a pic of my cars fuse box. Sometimes when Im pulling it feels like something may be screwed down underneath and I may snap it.
I know that all the small fuses and medium see through box fuses can be pulled without any problem. I've also managed to remove the big black boxes without any problem.
Will the coloured boxes also come out in the same way?
You can see I have highlighted one fuse in red bottom left positioned diagonally. This is a 120a fuse for the battery. I was trying to remove it however it seems very tight, i noticed some screws underneath it on some white plastic, would this need to be unscrewed first? I have added another picture which I think you can see the screw in.
Also I have highlighted some cartridges in the top in red, what are these and do they all pull out just like any normal fuse?
