My 2009 Honda Ridgeline has been making weird whirring noises when turning . The noises have been coming from the power steering. Should I get the power steering fixed right away, or will it last a while longer even if it is making whirring noises. I don't want the power steering to stop working in the middle of the road so should I get it fixed right away or will it last.
Any help would be appreciated.
    Have you checked the fluid level?
    – Moab
    Oct 15, 2019 at 15:08
I had a 1990 Honda Accord that had a very similar problem. It would often make a squealing/whirring noise when turning at intersections. The noise sounded like it was coming from the other side of the dashboard, near the power steering components.
I finally checked, and the power steering fluid was low. Filled it up to the correct level with the proper fluid, and the noise went away and never came back.
    While this may work for the mean time, the thing to think about here is why was it low in the first place? ... The power steering is "basically" a closed system, meaning it doesn't use fluid. If you had to replace fluid, the car lost it somehow. Oct 15, 2019 at 21:06
    I had the dealership replace the fluid and it works with no whiring noise! Oct 16, 2019 at 18:17
