-1
From outside, all doors will lock except drivers side door lock, using the remote. I can lock drivers side with key only. Then I cannot unlock any of the doors without using the key - or once I open drivers side lock with key, then the remote will open any of the other doors.
(tried with two remotes so problem not with remote)
  • 4
    What is the make/year/model of the vehicle? – Pᴀᴜʟsᴛᴇʀ2 Oct 8 '19 at 20:39
  • Hard to say much without knowing the year and model. – narkeleptk Oct 9 '19 at 21:05
Most likely the driver door lock motor/solenoid is bad. There is probably an interlock that won't unlock the rest of the doors until the driver's door unlocks.
Check the signal to the door, if it gets a signal when the command is sent then the motor is bad.
| improve this answer | |
