I've noticed that hood starts to vibrate at speeds greater than 100 kph. It's not something that annoys me too much but since my car is still under warranty I went to ask my dealer about it. From the dealership they told me that it's normal. Did anyone else experience this issue?
Since the dealership tried to upsell the breakpads on last regular service, I am not too keen on trusting them completely.
  • Welcome to Motor Vehicle Maintenance & Repair! Could you explain further what you mean by "vibrating"? Is it the hood which you see vibrating, or is this something you feel? If you are seeing the hood vibrating, there should be rubber snubbers located at the front corners you can adjust to meet the hood, which should keep it from vibrating (at least you'll find these on most vehicles). Sep 24, 2019 at 14:22
  • Just because it is normal does not make it acceptable, crappy build quality is no excuse.
    – Moab
    Sep 24, 2019 at 15:17
  • @Pᴀᴜʟsᴛᴇʀ2 Thanks for the welcome. I just see the hood vibrating from my driver's seat. Apart from that I don't feel anything in the car itself. Actually, the part of the hood which vibrates the most is central part closest to the windshield. Sep 25, 2019 at 5:33
  • If the vehicle is still under it's bumper-to-bumper warranty, I'd highly suggest you take it back to the dealership and tell them there's an issue. Sep 25, 2019 at 21:13
    It is a common problem, to the point that some Rav4's have been recalled in the past because their hood would fly open. I don't see a recall for your model year though - only older ones. Sep 27, 2019 at 18:54
