I have a 94 Corvettes that shut down after driving for a few minutes. I installed a new fuel pump. I think it’s the fuel relay. Only problem is I can’t locate where it is. I opened the passenger kick plate under the dash and I can see two relays the diagram shows there should be two groups of relays, one with two and the other with three. I don’t see the group of three. Do you have any suggestions
Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Sep 20 '19 at 13:20
Other than shutting off, why do you think it's fuel related? I can think of two other reasons the LT1 engine in your Vette would shut down like you describe. Have you put a fuel pressure gauge on the Schrader valve to see what the fuel pressure is doing? Does the car just cut out, or does it sputter to a halt? Does it start right back up after it quits? – Pᴀᴜʟsᴛᴇʀ2♦ Sep 20 '19 at 13:24
Add a comment
