I recieved a my new evap purge valve (for a 2015 ford edge sport) and it came with a major kink in the line. Is this still safe to use or will the line be damaged inside? I cannot separate it from the other parts to inspect it
"Is it safe to use a folded evap/vacuum line?"
No its not, They need to have high flow, either return it for another or use a heat gun on low to straighten it out and make it round again
  • If the heat gun doesn't make it right, remove it and replace with a high quality rubber hose (ask for fuel line @ local autoparts store.) You can also add hose clamps. Inexpensive fix. A lot depends on where you bought it... a high quality auto parts store will warranty an improper storage crimp like this.
    – zipzit
    Sep 19, 2019 at 23:19
