Your best bet is to check the various online parts catalogues such as Mintex, etc... Compare the image and dimensions in any of these catalogues to the pads physically in the car at the moment. What you'll then be able to do is cross-reference the catalogue part number to the manufacturers part number and match that up to the EBC catalogue.
I should point out however, if you're intention is to fit EBC Red Stuff pads to improve brake feel, you may find yourself struggling to stop when the car isn't being used hard. Performance brake pads are typically intended for fast road and track use and when they're not upto operating temperature, you'll find standard pads will perform better. You might want to look at EBC Green Stuff pads instead.
