According to manual for my car the recommended class of engine oil is: "API Service SJ, SL or above, ILSAC GF-3 or above"
Can I use ACEA A5 engine oil for this engine?
  • This type of question has been asked on here before....
    Sep 5, 2019 at 16:03
ACEA A5 is designed for European engines. You should not use it in an engine that doesn't specifiy ACEA A5
