A factory Subaru Impreza 2006 has 0.3mm2 ECU/ECM wires protected by 15A fuses while the service manual itself states that 0.3mm2 has allowed currency rating of 7A, that is 2 times lower than the fuse that is supposed to protect the wire. I would expect the fuse to be the weakest link in the circuit.
How does it make sense?
Snip from Subaru Service Manual - WI-7
7
"Allowable current" is not the same as "'This will start a fire' current".
While households effectively do use this standard, it is not commonly used elsewhere. As in this case, a fairly common standard is to fuse circuits for twice the nominal maximum. Fuses and circuit breakers are (outside of the very safety-conscious world of building codes) intended to protect against relatively short-term overloads, especially those caused by insulation failure and accidental short-circuits. Note that car manufacturers do not, in general, have to deal with random variations in loads in excess of the ratings. The loads for each circuit are specified and pretty well fixed. It's not like a family overloading a wall plug by adding Christmas tree lights or a space heater.
Allowable current is better thought of as "Operating maximum current". The 7 amp limit is applied to the specs for the loads to be attached to the circuit. If the loads malfunction and draw (for instance) 10 amps, this is unlikely to cause an immediate catastrophe. The wires will get hot, and the insulation will start to degrade more rapidly than is normal, but this is not generally something which is protected against.
  • Thanks! This is kind of what I thought. I was wondering how big is the safety margin in that "Allowable current". Is there a rough spec for wire diameters where it's not "Allowable current/operating maximum current" but the "You're insane if you go that far" or "Will throw sparks"? I understand that insulation has some temperature rating, so in my head if you exceed that, then you are in the "insane" zone. OFC alot depends of the surrounding environment.
    – tiblu
    Sep 4, 2019 at 13:29
