Hi I don't no if I will get any advice I got a car to mess about with just to learn about cars a bit more and the main beam will not work but the high beam does I have checked all the fuses and none of them have blown and I've looked at the wiring and can't see no splits or anything, any help would be appreciated
Have you checked the bulbs? Also the fuses can be broken not blown so it still looks good - try swapping fir a new one.– Solar MikeSep 1, 2019 at 20:20
Yes I have swapped the bulbs for new ones to rule that out and still nothing, I'm not to sure the location of the correct fuse to replace as I can't find anything online I took them all out 1 by 1 and checked there still connected in the middle and none of them were– Niall93Sep 1, 2019 at 21:49
