I'm having frequent hard starting issues & think the problem is the fuel pump relay. However, I have no idea where this is located, presumably under the dash somewhere. Anybody?
  • The first place I would check is the fuse and relay box in the engine compartment. The underside of the cover should have a diagram on it. – Jim Perris Aug 29 '19 at 0:17
    This parts diagram suggests it may be in the interior fuse box behind the left kick panel (just above the hood release if your car is left-hand drive). estore.honda.com/acura/parts/… – Jim Perris Aug 29 '19 at 0:41
Jim Perris comment is correct; Here's the location picture I found in my software...
07 Acura TSX Main 1 Main 2 (Fuel Pump) Relay Locations
| improve this answer | |
  • Thanks for the help. Found it. – Dan Sideen Aug 30 '19 at 12:26
