My 2014 Opel/Vauxhall Insignia 2.0 CDTI with a manual transmission has some acceleration problems in 4th 5th 6th gears.
In those higher gears if I floor the gas pedal, the car will accelerate and pull fine until it reaches ~2500 RPM, and then the engine will instantly rev up to ~3500 or above but won't pull, only if I take my foot off the pedal. Then the revs drop and pull. It feels like turbo kicks in at ~2500 and the clutch starts to slip?
If I gradually accelerate without flooring it, I can go over 2500 RPM in any gear and also I can floor it in 1st 2nd 3rd, it won't slip.
Are these all signs of a worn out clutch?
If yes, is it recommended to change the whole kit : clutch, pressure plate, flywheel etc?
Thanks!
