Good day, they threw engine oil in my transmission oil. What should I do and can I drive it like that?
    The shop that did it should do a trans flush and refill for free.
    – Moab
    Commented Aug 20, 2019 at 18:11
If it is an automatic transmission, then don't drive it, get it changed right away. The valve systems & clutches work under very fine tolerances and are not designed for engine oil.
if it is a manual, then should be ok to drive a short distance but don't tow trailers or heavy loads and get it changed.
