Implausible signal
Brakes fail
Very dissapointed
Is this noted for being from 1 wheel, because it may be an abs sensor fault - depends on the code. If the sensor ring has broken then the system does not get the expected signal.– Solar MikeAug 20, 2019 at 16:29
Welcome to Motor Vehicle Maintenance & Repair! What exactly is your question?– Pᴀᴜʟsᴛᴇʀ2 ♦Aug 20, 2019 at 18:09
