After i replaced the resistor for the blower motor the fan runs continuously. It doesn’t respond to the fan control knob even to turn it off. Also now the the a/c compressor is not kicking on. Is it a faulty resistor or do i have something else going on?
2003 Honda accord Trim package unknown 4 cylinder 4 door
The blower had just stopped blowing. After a little research I found out it is often the resistor that goes out on this model. So i purchased a new resistor 4 pin with heatsink. Simply plugs into factory wiring harness I took the old one out and replaced it with the new one. The switch was off no power to the resistor. When i turned the ignition switch on the fan came on. But only on wide open. If I turn the fan selector switch to off the fan keeps running. The a/c is not turning on though. Just the blower motor. It acts like the control console has been bypassed and the blower motor has been hot-wired to on.
