I have a Peugeot 307. All the lights are working, stereo etc when turning the ignition key to on, but when I turn the key to the start position it does not do anything but makes a constant buzzing noise which I can hear ( from under the bonnet ) coming from either the battery or the fuse box.
The battery is only 12 months old and all electrics are working. I can't see it being the battery ( I'm not a mechanic so I'm just guessing this ) I used the car this morning and it started with no problems, but a few hours later when I went to start it to take my daughter to the hospital and again now it wouldn't start!
I was given a push start and it bump started that way but after I turned the engine off I tried starting it again but it won't start. The emissions light is on the dash when it won't start, but when I bump started it and got the engine running the light went out.
Now it wont start again, the light is constantly on! I'm a single mum with a disabled child and I don't know any gentleman that knows about cars who can take a look at it for me and I can't get it to a garage or afford to have it done.
I'm hoping and praying someone on here could help me with some advice please on what the problem may be? I cant get around without my car so now I'm housebound. Thank you
    Try charging the battery and see if the problem subsides. It sounds to me like the battery is low. Aug 19, 2019 at 11:29
    To go with the above, on some vehicles when the battery is low, trying the starters operates a relay which provide power to the starter motor. The starter motor puts a large load on the battery, and so it no longer has enough power to operate the relay. So you get a rapid bussing noise and the relay activates / deactivates. This can be triggered by a battery on its last legs, or a charging system that has failed (so isn't charging the battery).
    – Kickstart
    Aug 19, 2019 at 13:15
