- Does BMW i3 has any spare wheel/tire in the car or in the trunk?
- If not, is there any recommended way to carry a spare wheel/tire inside the car?
See related discussions here: https://www.mybmwi3.com/forum/viewtopic.php?t=4080
Sign up to join this community
No, all you get a "Fix a flat" tyre sealant and small compressor.
The idea here is to save weight (longer battery range) and space.
BMW commissioned Bridgestone to make special tires just for this model. They are different from any other tire that Bridgestone makes (energy efficiency).
Even if you would decide to sacrifice your boot space for a spare wheel, bear in mind most countries have a law that spare wheel needs to be securely fitted or store away from the passenger compartment (boot fence e.g). Simple DIY to secure your spare wheel (if you can obtain one) might not cut it.
In my eye supplied tyre sealant (despite what mess it makes inside the tyre) is a good fix to get you to the nearest shop and have your tyre repaired.
Hope that helps.
