https://imgur.com/gallery/FbeIU8Y
Could anyone indicate where to look first? I’ve not had much luck. Checked the air filter, fuel lines. It runs smooth when it’s under high load (mower deck on and down)
Cheers! Andrew
  • Engine is trying to stall, but the governor kicks in to raise the rpm, carb is dirty or in need of adjustment. – Moab Aug 16 '19 at 15:08
  • Thanks for info. I took the carb apart and it looks clean. Jets are all clear. There are only two adjustment screws, one idle and don’t know about the other. Adjusting the unknown screw while running makes no difference. I’ve put it back to where it was. Any advice on where to look? Unfortunately can’t find the specific manual for this mower – andy-m Aug 17 '19 at 14:07
  • Make model and serial number? – Moab Aug 17 '19 at 18:36
