Had some vibration on a turn wheel while pressing my brake Mechanic Shop told me i need to replace my front pods and discs , Took it to a Pep boys for a second opinion and they said pods are fine for at least a year just need to turn my discs 57k miles on truck never got any brake service what's the deal
    Discs are not "rotated" as you might do with tires. Either you misunderstood them or they are idiots. It's not uncommon for brake rotors to warp as they wear out and that's possibly what you're feeling when turning and braking. But then it make also be wheel bearings which can generate the same sort of vibration as brakes. I'm guessing you're not mechanically inclined enough to take on a repair like this on your own. Go back to the original mechanic, who I assume you trust, and have them do the needed work.
    – jwh20
    Aug 7 '19 at 0:21
Did they say rotate your discs or did they say "turn" your discs. Turning means machining.
  • yes Turning is corect
    – Stevan
    Aug 7 '19 at 0:26
  • They can be turned in place on the car Aug 7 '19 at 2:45
