My 1999 Honda Civic DX won't start. I there is no crank so I started by checking the starter solenoid, there is no signal. Then I checked all fuses and relays including the main relay and they are all good. What do you think I should check next?
  • Welcome to Motor Vehicle Maintenance & Repair! Aug 1, 2019 at 0:19
  • Please explain how you performed the checks you have done so far.
    – HandyHowie
    Aug 1, 2019 at 8:12
    Is your car manual or automatic?
    – Progonat
    Aug 1, 2019 at 10:18
here are 2 diagrams to help you, first is for an automatic, second is for a manual trans.enter image description here enter image description here
